Version 2021 (12.1.1.8411) Date: 09/21/2021 1. Language Support English, Chinese, Czech, French, German, Italian, Japanese, Polish, Spanish 2. CAD Importer Support: Spatial 3D InterOp Release 2021 1.0.0 The following formats and their versions are supported: ACIS R1 – 2021 1.0 CATIA V4 4.1.9 - 4.2.4 CATIA V5/V6 V5 R8 – V5-6 R2021 DWG 2.5 – 2021 Inventor V6 – 2021 JT JT 8.x, 9.x, 10, 10.2, 10.3 and 10.5 NX NX 1 – NX 1953 Series Parasolid 9.0.x – 33.0.x Pro/E 16 – Creo 7.0 Solid Edge V18 – SE 2021 SolidWorks 2003 – 2021 STEP AP203, AP214, AP242 VDA-FS 1.0 – 2.0 3. Added support for 3Dconnexion SpaceMouse -Plug and play with full functionality support on both main graphics view and graphical report view -Allows all CMM-Manager commands to be assigned to SpaceMouse programmable buttons and radial menus 4. Rendering Improvements -Improved surface edge rendering utilizing Multisampling Antialiasing (MSAA) -Resolved edge trimming for tolerance band on Cloud-to-Curve graphical report 5. Path Planning Enhancements -Added collision avoidance for the upper extents of machine volume -Added link path option for Edge Points and Angle Points measurement -Checks and shows appropriate path planning adjustments warning for PH20 commands -Checks machine limits in all axes during program simulation -Fixed OD Cylinder path planning issue in PH20 all-axis mode 6. Feature Fitting and Construction -Added "Fixed Radius" fitting algorithm for Circle feature -Added option to allow using more than just the nominal axis as initial guess for cylinder fitting -Added option to construct a line from ellipse axis -Added option to construct a point by moving a point along its normal vector 7. Vision Enhancements -Added ability to pick CAD Points for vision -Added an option in parcentricity calibration to enable adjusting circle tool size dynamically based on video tip resolution -Allows iNexiv touch probe approach distance to be greater than 1mm -Fixed software crash on exit caused by image tools on floating image window 8. IPC Server Version 2.0 Update -Added more commands and new unsolicited event messaging mechanism to further facilitate client application integration See the spec document for details 9. New Client Monitoring App -Standalone companion application, free for users with active SSC -Connects to single or multiple CMM-Manager instances over company intranet -Monitors and displays useful information in real time including CMM usage / utilization, program running state, error events, probe rotation and trigger cycles, tip calibration status etc. 10. Other Enhancements -Improved points generation for Measure Cross Section and 2D Complex Curve -Allows batch change to DDE settings: file name, sheet number, dev. output option and incremental option -Allows grouping and sorting of Feature Database -Allows graphics update for PH20 block command execution 11. Driver Updates Caliper PCI Card: -Added 64-bit driver support Hexagon DC1: -Allows use of DONE button on joystick for Trigger Verify I++: -Add an option to select the last used probe for Set Active Tool prompt -Fixed: inconsistent PH20 tip handling of certain custom parts added in UCCserver -Fixed: connection error due to "bad property" when querying scan parameter of a touch probe -Fixed: "Incorrect arguments" error due to sending PCS for joystick -Fixed: older UCC congiurations may not support JogDisplayCsy command -Fixed: batch calibration of tips not already in UCCServer failed to clear the sphere Kreon Arm: -Added 64-bit driver support LK Controller: -Added option to home X-axis first -Fixed: joystick trigger does not always register -Fixed: SP25 closed-loop calibration may fail Mitutoyo UC: -Improved SP25 calibration especailly with longer stylus modules -Improved SP25 unknown scan data control - pitch and stop zone -Displays error during probe change when inhibit probe command is not supported by controller Mitutoyo UD1: -Fixed: driver may fail to load "UD1W.dll" Romer Infinite / MCA II Arm: -Fixed: connection issue on Windows 10 64-bit system using WinRDS Sheffield MP/SMP DCC: -Fixed: probe angle in DRO display not updating UCC Direct 2.0: -Fixed: "Incorrect arguments" error due to sending PCS for joystick -Fixed: older UCC configurations may not support JogDisplayCsy command zCat: -Fixed: "zCatParcer" error when connecting 12. Bug Fixes [1] Link path may not be created properly for Transform Rotate operation [2] Runout calculation for cone feature not correct [3] Shop floor launcher may crash on launching new program after running other program [4] CMM-Manager keeps Excel file locked after DDE operation [5] DDE does not always output Feature Geometry in current CS [6] DDE issue when minimizing CMM-Manager [7] Clicking on Define Tolerance button on a blank document causes CMM-Manager to crash [8] Customized keyboard shortcut settings are not sticky between sessions [9] Running a program with Auto Feature commands causes CMM-Manager to crash [10] On some systems there are missing and offset images in Excel report output [11] Best Tip for CAD Feature results in unsupported PH10 probe orientation [12] Changing GD&T Preferences from ASME to ISO does not stick [13] Program Runtime is not displayed correctly on 32-bit OS [14] Software crash when constructing a circle tangent to a line and a ref. frame axis at runtime [15] Gear Report Graphical variation bar graph is missing [16] Cannot create gear tips or gear inspection path with PH20 on certain internal gears [17] Gear parameter check (base diameter vs root diameter) is incorrect [18] OOT positional report items with "Feature Rpt" option may not be highlighted in the Report database. [19] Software crash when using Non-Repeatable Tip Calibration [20] SPACE key won't work as trigger after updating feature name on measurement counter dialog for manual system [21] Software crash after saving and load Measure & Scan Circle operation with 4th plane [22] CAD taught 2D Arc display incorrect after re-pick CAD
