Cloud to CAD and No results after verify
smudge611
Post by smudge611 » Fri Oct 18, 2019 2:01 pm
Processor: Intel Core i7-8700k CPU 3.70GHz
Memory 16 GB
Windows 10 Pro 64 bit
CMM Manager 3.9.2.7233
PH20 Probe Head
Okay,
I have been using Cmm Manager for a couple months now with varying results
When creating a program I randomly get report Cloud to CAD deviation put in my program.
As you can see in the screenshot below Auto create feature report is shut off.
The other issue I have with reporting is, the only way I can seem to get results is to run the program.
I can create a feature and verify it, but nothing will show up when I report it. Again see screenshot below Enable Live Report is checked.
Any suggestions?
Re: Cloud to CAD and No results after verify
Post by medupriest » Wed Oct 23, 2019 1:09 pm
The enable live reporting is what will create the Cloud-to-CAD deviation reports automatically.
To report something, you need to add a report step to your program from the report ribbon tab.
smudge611
Post by smudge611 » Wed Oct 23, 2019 1:16 pm
i do that and there results still show up with no deviation unless i actually run the program
Post by medupriest » Wed Oct 23, 2019 2:40 pm
I talk about the issue you are describing here viewtopic.php?p=5569.
smudge611
Post by smudge611 » Wed Nov 06, 2019 10:36 am
Any response on this yet here is a video showing the issue
https://www.dropbox.com/s/s6prneu2rcji7 ... 2.mp4?dl=0
Thanks
Post by Ryan Christopher » Wed Nov 06, 2019 11:00 am
In your preferences, you have a little checkbox: "Update Actual Feature" turned off right now.
Be aware that this little checkbox can be very important. I think of it as "the first of the 2 most important buttons in CMM Manager".
1. If you report as you go then turning this on won't hurt you at all.
2. If you program with CAD and create additional coordinate systems after measuring your features then it might be best to keep this turned off. In the off position, you will be certain that actuals = nominals. Without going into it, Ill just say that it is important for actuals = nominals when creating coordinate systems with cad.
Post by CrashN8 » Wed Nov 06, 2019 11:34 am
Can you show your work? Even I'm not quite sure what you're referring to...
smudge611
Post by smudge611 » Wed Nov 06, 2019 1:51 pm
Assume you mean this, it is turned off, I will turn it on and see if it changes anything
Post by Ryan Christopher » Thu Nov 07, 2019 10:32 am
Yes...This is the checkbox I was talking about.
