Static Image (Offline) Vision Program Sample
Software topics related to Nikon iNexiv and Retrofit Camera
Post by CrashN8 » Mon May 13, 2019 1:43 pm
I've provided instructions and sample files for complete Offline Image Inspection Example. This example allows 30 day trial or any current Vision User to demonstrate some typical CMM-Manager capabilities. See list of functionalities highlighted in this example:
  • VBScript MsgBox() is used to load one of two images during Program Execution
  • User Prompt for Serial Number or other unique data entry
  • Pattern Recognition - allows sample location and XY rotation to vary for each inspection
  • 3D or 2D CAD Alignment and Point Cloud Comparison
  • Report Output includes part graphic, text, header, etc. saved to .PDF file
  • Simplified User Interface Layout - load from .XML file
Instructions:
  1. Download all files below
  2. Import HelpDeskFile_Offline_Sample.ZIP from System Ribbon Tab>Configuration>Import
  3. !!! Make a backup of your environment by saving HelpDesk FIle from System Pearl !!!
  4. Restart software
  5. Load Vision_Offline.tip from Tip Manager (file is in Program Data... Resource directory)
  6. optional - Import & Load - Vision_Simple_LoRes.XML or Vision_Simple.XML - from Layout>Load dropdown
  7. Open Project - located in Configuration folder of HelpDeskFile
  8. Run Program and follow prompts
Demo Video:
Kifo
New User
New User
Re: Static Image (Offline) Vision Program Sample
Post by Kifo » Wed May 15, 2019 2:47 am
I tryed to run this demo, but cannot execute program offline because camera is not calibrated.
How can I set camera calibration without connecting with machine?
thank you
Post by CrashN8 » Thu May 16, 2019 2:17 pm
Check your C:\ProgramData\Nikon\CMM-Manager xxx\Resource directory. Is there a file called Camera.cam?
Did you load the Help Desk file per the instructions above? Besure to export your Help Desk file first.
Optionally, open the Help Desk.ZIP file from post and copy the Camera.cam file to your Resource directory.
