Tomelleri Arm
Tomelleri Arm
Post by CrashN8 » Tue Jun 02, 2020 9:44 am
Tomelleri Arm
Important Note - So far we have tested version no later than 3.7 SP1. We have not tested 64 bit version(s) of CMM-Manager that became available starting with version 3.8.
Must use CMM-Manager MCA I driver and TomelleriCore software
Update TCore parameter file - From Windows System Tray right click on TCore to access settings. From the Settings tab, under Parameter file #1 browse to the paramet.cms file on the USB thumb drive included with Arm.
Turn on MCA-Utilities Server - In TomelleriCore settings please check "Use MCA-Utilities Server" option as shown below:
Restore .REG - At the bottom of the Diagnostics tab click button [Restore .REG] then browse to the .reg file on the USB drive mentioned above.
Shut the entire system down and restart.
CMM-Manager Machine Setup - The Arm Utility Path needs to be the file path to Tomelleri's TCore software and not MCA Utilities.
For iOS / Mobile device click here to download the PDF file.
It appears you don't have a PDF plugin for this browser... you can click here to download the PDF file.
