Custom VB Dialog with Textbox and Dropdown
Post by CrashN8 » Fri Nov 02, 2018 3:11 pm
Here is an updated post describing how to create custom VB Dialog Box starting in CMM-M version 3.8.
In this case we want to create a dialog with drop-down box and input / text box for numerical input. The values from dialog controls are stored in variables var1 & var2, thus allowing math operations, flow control, etc. from the response of user. See the VB Script Function Reference in this thread for additional details on custom dialog creation - https://cmmmanager.com/forum/viewtopic.php?f=63&t=2974
Dim MyList (2)  'Initialize a static array
MyList (0) = "0.000001"
MyList (1) = "0.000005"
MyList (2) = "0.0000001"
'Create dialog object
Set dlg1 = CreateDialog(16,35,256,89,"Part Material and Temperature")
'Add system buttons
dlg1.Add_OKButton 204,24,40,14
dlg1.Add_CancelButton 204,44,40,14
'Declare variables to get the listbox selection
Dim var1, var2
var1 = 20
var2 = 0 'to select first item by default
dlg1.Add_TextBox 24, 24, 72, 12, var1  'Add a Text Box
dlg1.Add_DropListBox 124,24,72,40,mylist,var2  'Add a drop list box
'Add some static text boxes
dlg1.Add_Text 24,12,75,8,"Part Temperature: (C)"
dlg1.Add_Text 124,12,75,8,"Part CTE: (mm/mm/C)"
Button = ShowDialog ( Dlg1 )  'Show dialog
'Verify drop listbox selections
MsgBox("Temperature = " & var1 &vbCRLF & "DropListbox = " & var2)
Set Dlg1 = Nothing  'Destroy the dialog object after use
mcasey
Re: Custom VB Dialog with Textbox and Dropdown
Post by mcasey » Sat Jun 22, 2019 1:13 pm
I'm using the example code as a guide for making a dialog for entering nominal dimensions off of a print into a textbox except it keeps rounding decimals to the nearest whole number. How would I go about modifying the code to treat decimals as decimals?
Thank You
Dim MyList (9)  'Initialize a static array
MyList (0) = ""
MyList (1) = "9"
MyList (2) = "11"
MyList (3) = "13"
MyList (4) = "15"
MyList (5) = "17"
MyList (6) = "19"
MyList (7) = "21"
MyList (8) = "23"
MyList (9) = "25"
Dim MyList2 (6)
MyList2 (0) = ""
MyList2 (1) = "N"
MyList2 (2) = "A"
MyList2 (3) = "B"
MyList2 (4) = "C"
MyList2 (5) = "D"
MyList2 (6) = "E"
Set dlg = CreateDialog(350,75,175,315,"Part Parameters")
Size = 0
Clocking = 0
Front_Outer_Dia = 0
Flange_Width = 0
Flange_Dia = 0
Flange_Z = 0
Hole_Spacing = 0
Hole_Dia = 0
Rear_Ins_Dia_1 = 0
Rear_Ins_Dia_1_Z = 0
Rear_Ins_Dia_2 = 0
Rear_Ins_Dia_2_Z = 0
'Size Drop List
dlg.Add_Text 24,12,75,8,"Size"
dlg.Add_DropListBox 24,24,32,12,mylist,Size
'Clocking Drop List
dlg.Add_Text 74,12,105,8,"Clocking"
dlg.Add_DropListBox 74,24,32,12,mylist2,Clocking
dlg.Add_Text 24,50,105,12,"Front Outer Diameter:"
dlg.Add_TextBox 130,48, 32, 12,Front_Outer_Dia
dlg.Add_Text 24,74,105,12,"Flange Width:"
dlg.Add_TextBox 130,72,32,12,Flange_Width
dlg.Add_Text 24,98,105,12,"Flange Diameter:"
dlg.Add_TextBox 130,96,32,12,Flange_Dia
dlg.Add_Text 24,120,105,24,"Flange Depth:"
dlg.Add_TextBox 130,120,32,12,Flange_Z
dlg.Add_Text 24,146,105,24,"Hole Spacing:"
dlg.Add_TextBox 130,144,32,12,Hole_Spacing
dlg.Add_Text 24,170,105,24,"Hole Diameter:"
dlg.Add_TextBox 130,168,32,12,Hole_Dia
dlg.Add_Text 24,194,105,24,"Rear Diameter 1:"
dlg.Add_TextBox 130,192,32,12,Rear_Ins_Dia_1
dlg.Add_Text 24,218,105,24,"Depth of Rear Diameter 1:"
dlg.Add_TextBox 130,216,32,12,Rear_Ins_Dia_1_Z
dlg.Add_Text 24,242,105,24,"Rear Diameter 2:"
dlg.Add_TextBox 130,240,32,12,Rear_Ins_Dia_2
dlg.Add_Text 24,266,105,24,"Depth of Rear Diameter 2:"
dlg.Add_TextBox 130,264,32,12,Rear_Ins_Dia_2_Z
dlg.Add_OKButton 110,289,40,14 'on clicked will close dialog with (-1)
Do
result = ShowDialog(dlg)
Select Case True
Case Size = 0
Case Clocking = 0
Case Front_Outer_Dia = 0
Case Flange_Width = 0
Case Flange_Dia = 0
Case Flange_Z = 0
Case Hole_Spacing = 0
Case Hole_Dia = 0
Case Rear_Ins_Dia_1 = 0
Case Rear_Ins_Dia_1_Z = 0
Case Rear_Ins_Dia_2 = 0
Case Rear_Ins_Dia_2_Z = 0
Case Else Exit Do
'Button = ShowDialog ( Dlg )
End Select
Loop
Set dlg = Nothing
mcasey
Post by mcasey » Sun Jun 23, 2019 2:53 pm
Update:
I figured it out.
This section of code:
Size = 0
Clocking = 0
Front_Outer_Dia = 0
Flange_Width = 0
Flange_Dia = 0
Flange_Z = 0
Hole_Spacing = 0
Hole_Dia = 0
Rear_Ins_Dia_1 = 0
Rear_Ins_Dia_2 = 0
Needed to be changed to:
Size = 0
Clocking = 0
Front_Outer_Dia = 0.0000
Flange_Width = 0.0000
Flange_Dia = 0.0000
Flange_Z = 0.0000
Hole_Spacing = 0.0000
Hole_Dia = 0.0000
Rear_Ins_Dia_1 = 0.0000
Rear_Ins_Dia_1_Z = 0.0000
Rear_Ins_Dia_2 = 0.0000
Rear_Ins_Dia_2_Z = 0.0000
I am assuming that you need to include enough zeros to indicate how far out it should round to (i.e. least significant digit). Perhaps someone can confirm or deny this assumption?
