Groove with Circular Plane
Anegres1
Post by Anegres1 » Thu Jun 25, 2020 12:51 pm
Good day.
How can I Measure Groove with Circular Plane
Thanks in advance for your help
Best regards
Re: Groove with Circular Plane
Post by CrashN8 » Thu Jun 25, 2020 1:13 pm
Do you want to measure the bottom surface of a Face Groove on a Flat Circular feature? If so, you can just measure a single point at bottom and reference to top plane or you can use Circular Plane. CAD Teach Circular Plane allows you to pick plane directly or pick 2 concentric 2D circles to establish Plane boundaries. Do you have a picture or drawing or part that helps explain what you need?
Anegres1
Post by Anegres1 » Thu Jun 25, 2020 1:22 pm
Thanks for the reply.
I need to measure a square slot with sample points to define the height to measure, it is on an irregular pattern, with a 3mm probe
Post by CrashN8 » Thu Jun 25, 2020 4:18 pm
Use a bunch of Edge Point measurements then best-fit construction to create slot. During best-fit construction you can specify work-plane.
Anegres1
Post by Anegres1 » Fri Jun 26, 2020 11:45 am
Thanks for the feedback
