0.5mmX10mm Calibration Shanking Out
rrowsam
Post by rrowsam » Tue Nov 27, 2018 10:27 am
Hello, so I'm trying to add a the 0.5mmX10mm styli from renishaw and am having issues with the calibration. When the probe is measuring the cal sphere, it will shank out on the point it takes on the top of the sphere. With a 7 point calibration, all other points are fine and hitting in the center of the sphere, but the Z+ point seems to go just beyond the apex of the sphere and shanks out.
Any thoughts? I was thinking there has got to be a setting to adjust where on the sphere you'd like the probe to use to calibrate. With this setting, is there a way to adjust it for only 1 probe?
Re: 0.5mmX10mm Calibration Shanking Out
Post by Ryan Christopher » Tue Nov 27, 2018 11:52 am
This may be what you are looking for:
viewtopic.php?f=50&t=1557&p=5591&hilit= ... ngle#p5591
Post by CrashN8 » Tue Nov 27, 2018 3:10 pm
Actually no... This customer is not using UCC / I++ interface. I think the solution is probably related to Default Colatitude Angle settings in Preferences>General>Tip Calibration
