Change multiple feature tolerances
mcasey
Post by mcasey » Thu Apr 16, 2015 4:11 pm
I am writing a program to report the true position and diameter of 101 holes. I just finished when I realized that I forgot to change the diameter tolerance from our standard +/- .003" to the +.002/-.000" that is needed for this part. Is there any way to fix this other than deleting and starting all over again?
Re: Change multiple feature tolerances
Post by US_Helpdesk » Thu Apr 16, 2015 5:45 pm
Unfortunately no, we've added capabilities to batch edit DCC parameters recently. I have plans to do something similar for reporting. This will be in a release sometime in the future, until then you have to edit individually or redo the report items.
Post by Ryan Christopher » Fri Apr 17, 2015 10:58 am
Could perhaps using the SHIFT button in the feature database window to select and report all 101 holes at the same time help in this case?
Post by US_Helpdesk » Fri Apr 17, 2015 12:22 pm
Good question... Is this True Position or Feature Report output(s)?
If Feature Report then you can use the method Ryan mentions.
mcasey
Post by mcasey » Fri Apr 17, 2015 7:29 pm
It's True Position with the "Feature Rpt" option in the lower left of the dialog box checked. Then from the feature report tab it is set to output the diameter.
