Hard Probe Scanning with Manual System
Locked
US_Helpdesk
Post by US_Helpdesk » Mon Aug 15, 2016 5:36 pm
Hard Probe Scanning is supported on Caliper Designs PCI card and Insight Metrology IM-USB interfacce. To enable scanning, you must add "SCAN_RESOLUTION" entry into Driver\configuration file located here:
C:\ProgramData\Nikon\CMM-Manager 3.5 SP1\Driver
Open either IQSC100.ini (for Insight IM-USB) or CaliperPCI.ini (for Caliper PCI) and add the line
Code: Select all
SCAN_RESOLUTION 1.0        //hard probe scan resolution in mm
Of course you can change the scan resolution to specify the actual density of points captured during Hard Probe Scanning.
Note: The "Hard Probe" option must be selected in Probe Assembly dialog in order to enable Scanning / Hard Probe functionality. To measure with Hard Probe just select Measure Cloud from Blue measurement toolbar and choose Scan vs. Trigger option in measurement dialog.
Note: A Foot Switch or any normally closed switch must be wired inline with current Touch Probe to enable Scanning. See manufacture for details on switch.
I've migrated to a new user account, see my other posts here
RodGarrett
Re: Hard Probe Scanning with Manual System
Post by RodGarrett » Fri Sep 29, 2017 1:32 pm
Hi, is this something that can be done with a B&S Manbox setup?
Thanks
medupriest
SUDO
SUDO
Post by medupriest » Mon Oct 09, 2017 10:51 am
This is not supported on the ManBox.
Locked
