Reporting Length and Width Position of a slot.
Racinslack20
Post by Racinslack20 » Wed Oct 07, 2020 8:21 am
Hello all,
I am working on some stamping weldments that create and automotive sub frame. I am starting to program some of the features to be measured and had a question about the GD&T on this particular area. It is calling out position on the length and width of this slot. It also is saying Datum C is just the width. Could someone help on how I would set this up. Both reporting the position of length and width and also how to label just the width as Datum C? Thanks in advance!
Re: Reporting Length and Width Position of a slot.
Post by Ryan Christopher » Wed Oct 07, 2020 10:10 am
Hi Racinslack,
Can you point to datum A? Assuming datum A is a plane, there are 2 possible outcomes here (Table 4-4, Y14.5.1M 1994, Case 3.13 or Case 3.14).
Racinslack20
Post by Racinslack20 » Wed Oct 07, 2020 10:40 am
Ryan,
Datum A comes from 4 datum targets on the body mounts. I generally pick up a point on each one of these surfaces and create a Plane from those 4 points.
Post by CrashN8 » Wed Oct 07, 2020 12:39 pm
Bilateral Position will allow this callout for Position of Slot feature with (MMC) modifier. I might suggest measuring as Round Slot, but then export Raw Data (on straights) and reconstruct as Open Slot for sake of creating Datum C feature.
Racinslack20
Post by Racinslack20 » Wed Oct 07, 2020 2:33 pm
Ok so make open slot from points (on straights) for datum C. As for the positional reporting, use the open slot for reporting the width? What about reporting position of the length?
Post by CrashN8 » Thu Oct 08, 2020 8:55 am
Measure Round Slot
Construct Cloud - Extract Raw Data
Construct Points From Cloud (just pick points on straight sections)
Best Fit Construct Open Slot
Now you have TWO Slot Features in Program but only measured once.
Racinslack20
Post by Racinslack20 » Thu Oct 08, 2020 10:33 am
Ah Okay. I didn't think to use the initial slot. Thanks Crash!
