I've provided instructions and sample files for complete Offline Image Inspection Example. This example allows 30 day trial or any current Vision User to demonstrate some typical CMM-Manager capabilities. See list of functionalities highlighted in this example:
VBScript MsgBox() is used to load one of two images during Program Execution
User Prompt for Serial Number or other unique data entry
Pattern Recognition - allows sample location and XY rotation to vary for each inspection
3D or 2D CAD Alignment and Point Cloud Comparison
Report Output includes part graphic, text, header, etc. saved to .PDF file
Simplified User Interface Layout - load from .XML file
Instructions:
Download all files below
Import HelpDeskFile_Offline_Sample.ZIP from System Ribbon Tab>Configuration>Import
!!! Make a backup of your environment by saving HelpDesk FIle from System Pearl !!!
Restart software
Load Vision_Offline.tip from Tip Manager (file is in Program Data... Resource directory)
optional - Import & Load - Vision_Simple_LoRes.XML or Vision_Simple.XML - from Layout>Load dropdown
Open Project - located in Configuration folder of HelpDeskFile
Run Program and follow prompts
Demo Video:
I tryed to run this demo, but cannot execute program offline because camera is not calibrated.
How can I set camera calibration without connecting with machine?
thank you
