1. Check communication settings in current software
- - Sharpe: COM 1 4800 E 7 1 // com interface (port,baud,parity,data,stop)
- Leitz: COM 1 9600 N 8 1 // com interface (port,baud,parity,data,stop)
- - Sharpe: Either Downl.oad or Syspar (older systems) will exist on the PC (see install guide for location)
- Leitz: All config is stored on controller there should be no config file stored on local PC
- - Start Hyperterminal, and press Ctrl+ECB.
- If it is Leitz protocol, it should display “Ready”, and further command can be issued, e.g. “TESTSOFT”
- - Sharpe Protocol
- a. dongle on "Servo Key" connector
b. RS232 cable on H1J0 (DB9 female)
c. RS232 cable on H2J0 for Renishaw PHC 9/10
- a. no dongle
b. RS232 cable connected to DB9 male connector next
to "Servo Key" connector
If system is Leitz see this install guide - https://cmmmanager.com/forum/viewtopic.php?f=11&t=267
